2nd Gen Non-Engine/Transmission clutch fan
Engine/Transmission (1998.5 - 2002) truck won't start
Engine/Transmission (1994 - 1998) 1998 12 valve fuel filter specs
What would be the proper way to check the clutch fan to determine if working proper? The cold air from the center vent on a 90 degree day will run at about 47-48 degrees at 55-60 mph but at idle on the same day will run 43-44 degrees?
Don
sounds like it's doing something to get it that cool at idle, some systems will drop a few degrees at high speeds due to the compressor cycling where idling it's on mostly constant. a good sign of a working clutch is a occasional chirp at shut down as it slips the belt but that's not law
