Engine/Transmission (1994 - 1998) Clutch Housing to Flywheel Bolts
Clutch to Flywheel Bolts
This is an auto to manual conversion and the shop manual doesn't clearly show the bolt set up.
What grade are the bolts holding the pressure plate assembly to the flywheel and do they require washers (flat or split)?
Bolt dimensions would be useful as well, but I can probably figure that out.
