I took some pictures while installing my soutbend clutch a year ago planning on posting a how to segment on my website. Never got around to it and now I've forgoten quite a few things about the install. Take this as just a guide and not a step by step instruction manual. I'm sure everyone will jump right in if I get something wrong so here it goes.
Start inside the truck. With a phillips remove the screws holding the shift boot and slide it up.
Remove shifter with 3/4" or 19mm wrench.
Pop up transfer case shifter boot and remove bolt/s. Pull out rubber inserts in cupholders and remove bolt/s. Remove plastic shroud.
Unbolt shifter boot.
Unbolt shift tower carefully and tape clean rag in hole. If you drop anything into the trany like one of the bolts or a socket it's all over.
