In two years I have replaced the hydraulic assembly for the clutch 3 times, now that I am on the fourth one it seems to be going out again. Small signs are telling me the it is going to blow any moment. The master cylinder is starting to squeak and it is hard to get into gear sometimes. I have no idea why this is happening? The dealership just keeps giving me new ones at no cost because of the one year warranty on parts. But something has to be causing this. Otherposts have said to:
check that the diaphragm spring on the pressure plate is not distorted or weakened, and that the pivot ball on the passenger side is not worn out. Also check the clutch fork for wear. "
How do I check the the diaphragm spring on the pressure plate and the clutch fork, just unbolt the bell housing?
Any other ideas?
Any other ideas?
