2nd Gen Non-Engine/Transmission Clutch pedal engages too high
Engine/Transmission (1994 - 1998) Truck Won't Always Shutoff
Engine/Transmission (1998.5 - 2002) transmission chatter?
Any way to move engagement point closer to floor?
I have removed the slave cyl and pushed the rod in slowly by hand 5-6 times hoping to maybe move some air from the system but it didnt help.
The rod takes a fair amount of pressure to push in, is that normal?
Has anybody had this problem and solved it with a new master/slave cyl unit?
The engagement point has been about the same with 3 clutches and currently there is a new SB CON OFE in there.
TIA
John
John,
When I drove your truck a couple of months ago the clutch pedal throw felt good to me. Has it changed? I personally like the clutch engaging near the top of travel though. Beats grinding gears if you don't press the pedal all the way to the floor.
On edit, check your PM.
Gary
