My transmission has gone from hard to shift to wont shift. There does appear to be a slight leak at the slave cylinder but the fluid level at the master cylinder looks good. The clutch engagement point however is at the floor. If I'm stopped I have to turn off the motor to put it in gear. . The truck does lunge a little with the starter but I can get it going. One other peculiar thing it does, when idling in neutral with the clutch depressed, when attempting to get the truck in gear it will start to move. I can actually rock it back and forth by attempting to put the truck in reverse and then first gears. I'm not even getting it in gear and it's moving
Once moving the truck will shift OK.
What's happening? Can I drive it this way to the shop who put the clutch in ( 300 miles away) or should I just limp over to the local shop and cross my fingers?
Thanks, AC
Thanks, AC
