Clutch Question
KN-RE0880 prefilters?
three legged Dodge cummins
I got a 96 with 4 wheel drive and about 67,000 miles I lost 5th gear and just got my transmission back after having the upgraded shaft from standard transmission installed. I got the centerforce clutch since i had the transmission out anyway. But now I'm pretty sure that the flywheel is the bimetalic type (at least thats what i heard) since you cant cut them and I don't want to lay out another 500 bucks can I just use the new clutch or should I leave the old one in until I feel like spending money for a new flywheel?
I believe my service manual says not to turn it. I had it turned anyway and I don't notice any problems. I am not sure if I got this out of the manual or where but, but supposedly the face has a slight contour to it to help eliminate chatter or something. If it is bad I would surface it.
I had mine cut.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors,16cm2 turbo housing, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
