Greetings,
I currently have an SBC Con0 in my 6speed (12 inch flywheel) that has suffered from alot of Idle clatter from the day it was installed.
SBC has said that some make noise, and sometimes they get quieter, and some dont. This one is still loud after 6 months of use.
It was totally quiet with the stock clutch.
Up until now, this Con0 had a great feel, but now it is starting to feel like the center hub may be coming loose, because when I take off from a stop, is has a slight slip, then grabs. it only does it once until I use the exhaust brake (slipping it in the reverse direction), then it will do it again on a take off. It will never do it twice, without putting a reverse torque on it first. This makes me think the center hub may be slipping back & forth and about ready to fail.
I sure dont want to pull the 28' trailer this way.
So, I kind of could use some advice. It looks like Im going to have to run it back to the $teal-er, and have them pull the trans & check the clutch.
If it is the center hub going bad, what is the best way to go on a new clutch?
Upgrade my 12" to a 13" SB clutch? McLeod? Modified Sachs?
Time for a real clutch.
I acknowledge that SBC has great customer service, and would probably be fair with me on an upgrade, but at 600. 00 labor per failure, customer service doesnt help much.
I want a clutch that will handle pulling heavy, and handle it if I want to go with more power. . Like upgrading my DD1's + Va to DD3's + Va.
I'm thinking the Mcleod may be a safe way to go, just not sure how hard a solid hub is on the transmission. And isnt that still a 12", or do they have a 13" upgrade kit?
Is 13" necessary?
Also, is there a bronze bushing Pilot Bearing available?
Any input would be appreciated.
Thanks, & My best wishes go out to Nowel Thomas & Steve St. Laurent.
Is 13" necessary?
