DH,
Its a lot of work to pull a trans when the problem MIGHT be elsewhere. The pedal/slave blocking technique is not generally taught, I have not seen it in a service manual, but it is very effective.
Several times when clutch failure to release issues come up, the pilot bearing often is found destroyed.
I did this once on a 5 speed. I removed the S/C and installed the same puller that I used into the B/H and used this as a temporary release system. I think the numbers for total travel at the screw would be in the range of 5/8-3/4" at the screw. With the system "released" put it in gear (engine off) and try to turn the d-shaft.
When I test a pedal system or an entire clutch, the total pedal travel gets broken down into 3 phases.
Releasing the clutch, press pedal down.
1st 3rd of travel tightens up the system increases pressure, bearing travel almost releases clutch but not yet.
2nd 3rd, pressure plate moves away from disc, clutch starts release process.
3rd 3rd, clutch released, in reserve release travel zone.
Engage the clutch, pedal comes up.
1st 3rd, reserve travel is reversed, pressure plate starts to move in the direction of the disc, initial contact with disc.
2nd 3rd, the Friction Zone, the pressure plate increases pressure applied to the disc, disc compresses, disc RPM is accelerated up to engine speed.
3rd 3rd, pressure is released completely except for bearing preload applied by S/C.
Your results may vary based on system type, age and wear, disc thickness and "lining spring" extension and compression and the effectiveness of the release system.
