Howdy,
Okay, my truck will not start when you press the clutch; even crammed to the floor. But if I reach under the dash and pull the switch toward the seat till it stops, my truck will crank fine. I crawled under the there to have a look see and it seems that (like I read in the archives) that the eyelet on the pushrod for the mast. cylinder is worn sorta out-of-round. Or the rod it rides on is worn? What should I do? Put a spacer under the switch? Remove the whole assemblage(sp?) and do some welding? Sorry its so long, any help is appreciated.
Thanks, Steve
Thanks, Steve
