Engine/Transmission (1998.5 - 2002) Clutch
2nd Gen Non-Engine/Transmission Abs?
2nd Gen Non-Engine/Transmission Changing rear gears
Plan on installing a south bend single disc clutch in a 2001 HO with 130,000 miles. Stock except for injectors, exhaust, and intake. Does flywheel need to be replaced also?
Is this something that should be well known for a shop that resurfaces them. Also when I convert my G56 to a NV5600 the flywheel as new will not need a slight resurfacing, like brake rotors should have a slight resurface to make sure of flat surface.
