I don't have evidence of the photo, but the specs on the different engine's bore and stroke are easily accessible on the web. The Cummins has 6 cylinders versus the competitions' 8, but with similar horsepower and torque levels. Each cylinder is pumping out more pow-uh than the equivalent cylinder on an V8, and accordingly a stout rod is required. A longer stroke requires a
longer rod, and a more powerful stroke requires a
beefier rod. To satisfy both requirements you must have a long, beefy rod.
The disgruntlement the rod picture evokes in the hearts of Powerstroke and Duramax fans everywhere is simply envy, they are ashamed to be seen in the shower when the mighty Cummins goes strolling by :-laf :-laf
http://www.meadowlandford.com/2003 Power Train Specs.htm
6. 0 Powerstroke
bore x stroke = 3. 74 x 4. 13
displacement = 363 (5954)
Compression ratio = 17:1
http://www.fordf150.net/specs/02fsuper.htm
7. 3 Powerstroke
bore x stroke = 4. 11 x 4. 18
displacement = 444 (7277)
Compression ratio = 17. 5:1
http://www.truckinweb.com/brandpages/chevy/0508tr_dura/
Duramax
bore x stroke = 4. 06 x 3. 9
displacement = 403 / 6599
Compression ratio = 16. 8:1
and, to avoid claims of bias from the Ford folk:
http://www.meadowlandford.com/ford-f650-f750-cummins-engine-spec.htm
Cummins 5. 9
bore x stroke = 4. 02 x 4. 72 in
displacement = 359 cu in, 5883 cc
Compression ratio = 16. 5:1
