My truck which is a 2k dually automatic thats stock with 166k miles just started to run erractic and mis like someone is cutting the key off and then died, sometimes it will start up and go for a few miles and cuts out again , all of this happened going down the road like 30 miles into driving, I let it sit until the next morn and it did it again in 30 miles, I ran the codes and got 1690 which reads fuel pump ckp sensor does not agree with ecm sensor, my lift pump pressure is 13 going down the road but will fluctuate when this happens and my truck has both the cam and crank sensor. I actually changed the crank sensor with a known good used one and its still doing it, could the cam sensor be bad too? actually both the sensors only had 30k miles on them when this happened, as far as I know the stock vp 44 still on it! I hope someone can help, this is the only code I have got that came up on my scanner.
