Does anyone know what this means? DTC code set? What is this?
Ok, I checked again and found 0177 water in fuel however as I understand it the water in fuel sensor is in the factory fuel filter housing and I no longer have one since my fass is direct to the vp is there anything else that could trigger this?
Is your stock filter housing still mounted & plugged in? If not you may just have corrosion in the plug that went to the sensor.
