I did a search on this code and found that this is what it means,
P1740-TCC O/D SOL PERFORMANCE (DIESEL)
For the Transmission circuit diagram (Refer to 21 - TRANSMISSION/TRANSAXLE/AUTOMATIC - 48RE - SCHEMATICS
AND DIAGRAMS)
For a complete wiring diagramRefer to Section 8W
Theory of Operation
The Torque Converter Clutch (TCC) Solenoid is used to engage the TCC which inproves fuel economy.
² When Monitored:
The Torque Convertor Clutch (TCC) and Overdrive Clutch (O/D) will be tested each time the ECM requests
TCC engagement in 3rd gear and O/D.
² Set Condition:
The DTC will set if the expected RPM drop is not achieved while attempting to engage TCC or O/D. This
indicates a malfunctioning torque convertor or overdrive clutch.
I have a Suncoast transmission in my truck, and this is the first "problem" I had. The truck drives fine, and still has O/D. While searching on this site, it seems that this code will come up a California emmisions truck with a tight T/C under certian conditions.
I am in CT, but my truck came from Long Island NY. Does NY use the same emmissions standards as CA? If so, maybe it will be something I have to live with?
AND DIAGRAMS)
Theory of Operation
² When Monitored:
² Set Condition:
