Engine/Transmission (1998.5 - 2002) Code Dump
2nd Gen Non-Engine/Transmission ABS concern
Engine/Transmission (1994 - 1998) Altenator troubles
I have tried multiple times to get the codes to diplay on my odometer with 3x on -off discribed here on TDR. I know there are codes present, but no joy. Does this procedure work on pre 98. 5 ? and not on on a 98. 5 ??
Should the odometer be on the trip or milage display.
Any advise would be appreicated,
Cheers,
Matt
I think that this trick wont work on the early 24V. I tried on a friend's 98 and never could get anything to come up, but it works on my 00
I'm in Los Alamos Ca. about 50mi North of Santa Barbara. .
I ordered the truck in Feb 98 form Dodge Fleet Sales on the Web. They called and asked if I wanted the 12v or 24v. I went 24v and took delivery in July 98. So, I'm sure it's first run 24v ISB. Completely built in Mo. USA woo hoo !! I was impressed that they invited me out to check out my truck as it was built !!
OBDII code reader ?? are they reasonably priced ??
Thanks for the GREAT Responses !!
Matt
code reader
Mat the reason I asked was if you were local you could use mine. I would bet that you can find someone in your local club that has one.
If I remeber correct that year you can turn the key off and hold down the odemiter reset and it will flash the codes for you. I might be wrong it may be turn the key on. Try both maybe someone can correct me
