Code P0514
Loss of Power at Highway Speeds
Injector Problem??
I just got back from the dealer for the same code. This is the second time in three weeks. It is getting old. It seems to happen only when it gets Very cold, around 0. They say that nothing is wrong, It's a false code. They are woking on a fix , so I am told.
This is getting really old! Last Wed. I got this code cleared. I started my truck up after work today and it was back. This is the third time since Christmas! Are you guys having this kind of luck with this? Any fixes?
Service manual info on Battery Temp Sensor
Here's some text straight outta the Service Manual which might help.
Or bring up even more questions... .
"The Battery Temperature Sensor (BTS) is attached
to the battery tray located under the battery.
"The BTS is used to determine the battery temperature
and control battery charging rate. This temperature
data, along with data from monitored line
voltage, is used by the PCM (ECM Diesel) to vary the
battery charging rate. System voltage will be higher
at colder temperatures and is gradually reduced at
warmer temperatures.
"The PCM sends 5 volts to the sensor and is
grounded through the sensor return line. As temperature
increases, resistance in the sensor decreases
and the detection voltage at the PCM increases.
The BTS is also used for OBD II diagnostics. Certain
faults and OBD II monitors are either enabled
or disabled, depending upon BTS input (for example,
disable purge and enable Leak Detection Pump
(LDP) and O2 sensor heater tests). Most OBD II
monitors are disabled below 20°F. "
aJ
i've been driving around with mine for who knows how long whats the deal if i would have never checked for the codes i wouldn't have even known they were there. the moral of the story is it isn't hurting anything to have it tripped.
