Engine/Transmission (1998.5 - 2002) Code # p1689 ???
2nd Gen Non-Engine/Transmission Going to rewire light switch
Engine/Transmission (1998.5 - 2002) White Soke ???
I am wondering if any of you have had this code with these symptoms.
4 days ago I was on the highway, let off the throttle to let someone
merge in, stepped on it again to resume speed. Engine bucked a couple
times real quick. Check engine light came on & dead pedal. Went up an
exit ramp & engine died. Cranked it over & it started right up. Ran alittle
rough & the idle went between like 800 & 1100 rpm's. Went into a store,
came out about 15 minutes later & all is ok. Check engine light was still on,
checked codes at home & p1689 came up. Cleared codes and ok for 2 days.
Again I was on the highway, towing about 9000lbs, Bucked alittle, check engine light on, but no dead pedal. Drove for about 30 miles ok, pulled over
to eat. Check codes again, code #p1689. Again idles went up & down. Disconnected EZ box & restarted, it ran worse. Reconnected EZ & noticed
alittle corrosion on one of the plug pins. Cleaned it with a tooth pick. Cleared codes & drove about another 100-150 miles ok. When I got to work this morning, idle was alittle rough, no codes or check engine light. Went to lunch
& all seamed good. Any Thoughts?? VP?? ECM?? Wiring?? No other plugs or pins were corroded. Thanks
b. t. w. it is a 01. 5 2500, ez, dd2, vulcan, b-1, 4", bhaf.
Have you checked to see what the code means? If not here is what I pulled off of here,
P1689 (M) No Communication Between ECM
and Injection Pump Module
Data link circuit failure between ECM and fuel injection
pump. Low power, engine derated, or engine stops.
So I would guess it is something between your injector pump and your ECM. Hope this helps .
