code problems
turbo ringing at idle...
Low Boost
According to my service manual P0606 is "ECM Hardware Fault". Sounds like a fried ECM to me. Also check TSB.
Ryan
I Can Use My Scan Tool And Get Rid Of The Code And Then When I Make A Long Road Trip It Comes Back On. . Just Curious If This Common Or Just Something I Should Be Worried About?
Then it's probably a loose or corroded connection at the PCM or ECM. I'd pull the connectors on each and clean them. Certainly can't hurt.
Ryan
