I just purchased an 07 2500 6. 7L 6spd QC SB with 61k miles from a dealership (after recently selling my 99 2500 5. 9L 5spd QC SB w/ 165k)... hoping it was a good call. The 99 was super rusted out and needed 'some work'.
Anyway, unbeknownst to me, the 07 has some mods and came with the MADS Smarty S67 programmer. I want to make sure I know what I've got here and need a little education. I'm leaning on the side of efficiency and fuel economy with this truck. Not looking for a hot rod and only haul a couple thousand lbs of steel/wood every few weeks, if that.
I ran the Smarty, set the settings to 'stock' (from setting #1) and found that it is throwing some codes (P0031, 0037, 144E and 2345C). AND the check engine light just came on after only driving it for about 45min today. AND there is a 'jerking/slight shuddering' at slow speeds and light throttle...
Aftermarket exhaust is 4" stainless (no name visible). See attached photo. Has the exhaust filter been removed? Is this good? What does this do for performance/economy?
It has an AFE cold air intake (see image). How do I know which model it is? Does that matter? More air is always a good thing, right?
There is a mystery toggle switch on the dash which is obviously connected to the yellow line that goes into the exhaust manifold(?) above the turbo. (see image) Any idea what this switch is?? Does this have anything to do with the disconnected sensor/cable I found tucked in behind the top of the engine? (see image) Given how dirty this cable connection is, it's been off for a little while...
There are pillar mounted EGT and Boost gauges. I'm assuming I need to monitor the EGT carefully? Will I need to worry about this if I'm not running anything above stock or setting #1 on Smarty?
Any thoughts? I have two top notch diesel mechanics locally. One is a cummins specialist. This is my first vehicle with a warranty, so of course I'll want the dealership to do whatever work they can. But, as with previous cummins (and VW TDI) vehicles I've owned, the specialists seem to have a better handle on the finer points of their maintenance and repair. Correct?
Thank you.
Jonathan
Thank you.
Jonathan
