codes PO137/P2A01 what to do?
Help? Truck running codes after an attempt at MP-8 install
Mag Hytec
I had AutoZone tell me I had these codes. I just started a 4 month trip, towing a 14K toyhauler. I'm out of warranty and have had all the recalls done. My question is, can I wait till I return home or will there be a problem if I don't replace the Oxgen Sensor on Bank 1 Sensor 2? Also, is this an emission problem, and would it be covered under warranty?
Thanks, ron ______________________________________________________________
2007. 5 3500 SLT 6spAuto DRW AIRAID MXP 4:10 ratio EGT/Trans Gauges
Your cat might be plugged, it set these codes in
your ecm. Try disconnecting you batteries for 1/2 hour
it will reset codes. Works on my 05.
If you are not past 100K miles, your warranty for the Cummins engine is intact. See below for info on the codes:
P0137-O2 SENSOR 1/2 CIRCUIT LOW
Theory of Operation
The engine aftertreatment system monitors the O2 content in the diesel engine exhaust. The ECM monitors the exhaust gases for oxygen content and varies the rich/lean fuel mixture of the intake air fuel mixture to adjust the system. This diagnostic monitors the status message broadcast by the Smart O2 sensor module for the downstream O2 sensor circuit. The ECM will set the fault if it receives a FMI (Failure Mode Indicator) message from the Smart O2 Module. The ECM will illuminate the MIL lamp immediately when the diagnostic runs and fails. The ECM will turn off the MIL lamp diagnostic runs and passes in four consecutive drive cycles.
When Monitored:
This diagnostic runs when the engine is running.
Set Condition:
P2A01-O2 SENSOR 1/2 CIRCUIT PERFORMANCE
Theory of Operation
The engine aftertreatment system monitors the O2 content in the diesel engine exhaust. The ECM monitors the exhaust gases for oxygen content and varies the rich/lean fuel mixture of the intake air fuel mixture to adjust the system. This diagnostic checks to make sure that the O2 content matches the expected O2 content for the engine operating conditions. The ECM will set the fault if it detects that the actual O2 measurement does not match the expected value. The ECM will illuminate the MIL lamp immediately when the diagnostic runs and fails. The ECM will turn off the MIL lamp diagnostic runs and passes in four consecutive drive cycles.
When Monitored:
Set Condition:
I would not let this go on for long. Take it to the dealer and have it checked. Many of these errors codes can cause the engine to de-rate itself if you continue to drive it for a few hundred miles. If it does this, the truck will struggle to climb a hill and may start to plug the DPF and create even more problems.
Thanks
Thanks, everybody, for your reply. I am now just getting my messages, as we are traveling and don't always have access to WIFI. At our next stop I will check with a Dodge Dealership.
Thanks again,
Ron
Updatge on PO137/P2A01
First, I want to thank AHolt and Pfranzese for their input, plus the detailed description from dimetzger and Brandon for helping me on this Thread.
I took my truck to a Dodge Dealer and they replaced the downstream Oxygen Sensor and Module, which were under warranty. Researching further on my 2007 Warranty Information Booklet, on page 18 & 19, “5. 2 Federal Vehicle Emission Warranty 6. 7 Diesel Equipped Heavy Duty Truck”. “A. Parts covered for 5 years or 50,000 miles. Oxygen Sensors and Oxygen Control Module. ”
With 42K and under 5 years, I made it! TDR and you Members saved me a lot of time and money.
Thanks again,
Ron
