Details here: TDR Privileges
Is the check engine light on or abs light on? If not then don't worry about it. Either go and buy a hand held scanner or the dealer to pull codes when you have a MIL (malfunction indicator light) that comes on.
Turn the key from off to on, real fast, 3 times. Leave it in the on position. The odometer will display codes is succession. When finished, the odometer will spell DONE.
