Codes
Crankshaft position sensor code?
P0148 and More!!!
Trucks throws code P0628 stops running will restart runs about 5 secs. then
quits, let sit for about 3hrs it restarted suggestions for repair.
2004 2500 with 5. 9 cummins,aallso do you know where the pump relay is located looked
in fuse box no listing for fuel pump relay THX
Turn the Key and listen to it run (do not start engine), it should run for 25 seconds,Turn key off wait 3 minutes and do it again, You are trying to find out how long It will run before shutting off,Listen closely, if its humming chances are its good, if buzzing it needs replacement.
My pump was intermittent before it failed. Would do it on the freeway. It would just go dead, then fire back up. It finally did it to where I had to pull over. I cranked it about 5 times before it fired back up. I was able to make it home before it went completely. Truck threw the same code. I replaced it and its been fine ever since. TCDiesel is right on for testing it.
