DaveK98 said:Guys, Is my 05 equiped with a block heater?
I think all I need to buy is a cord right?
The only STUPID question is the one that is NOT asked!JRihani said:I know that is probably a stupid newbie question, but I was just wondering.
You are one SIC puppy!!NavyDood said:I'm from MI and I love cold weather...
jwduke said:I dunno, if you plug it in, when the motor is at operating temp. , wouldn't it use less electricity, than if a timer started warming up a -10* block???
JasonCzerak said:The viscosity of oil changes with heat. Could placing one of these on the oil pan make the oil "thicker" (at the '45' of the 15w45) and there for harder to pump when starting a cold motor?
This is the argument that my buddy and I had a few times.
But in practice. block heater at 0 degree the motor turns over and fires like it was 90 degrees out. With out the block heater, even before things fire, you can tell that it's trying much harder to turn the crank. This would be the oil viscosity or just cold vs. warm metal on metal friction?
Also practice tells me that, oil seems to flow much faster out of a warm motor then does from a cold bottle (pouring in. )
billyfury said:Does this sound normal?
Thanks, billyfury 70-71 Fury Collector (24 and counting)
