Driving an '02 HO w/6spd. Had the stealer activate the high idle feature about a month ago. Took two trips, the 1st they couldn't figure it out and the 2nd I took the procedure and they said the program was "mysteriously found" and turned on. A few mornings the low temp has been around freezing... according to the thermometer in the cab... but I have usually been out later that night and start it early the next morning and just figured the block hadn't cooled down enough to kick the high idle feature on. This morning the thermometer in the cab said it was 27F, yet no high idle. E-brake is set, trans. in neutral, and temp guage is at left side. Didn't touch the throttle or the brake. My question for you folks is: Does your high idle feature kick on at 32 exactly or is it usually a little cooler or does it vary?
Appreciate the help.
