All right Oo. I see my first clue here to what I think is your problem with getting heat into the cab. I say you have a flow issue. I see in the picture that both heater lines from the cab run forward to the front of the engine. I see one going to the pump side and one to the top of the block either just below the thermostat or above it. On my 2001, my intake line to the heater core comes off the back of the engine between # 5 and #6 cylinder on the head and my other line runs forward to the return side of the pump. I get a good differential pressure and get the heat off of the entire head assembly with the flow from the heads. What I see in the picture posted leads me to believe that you do not have enough differential pressure for a good positive flow. I would take your input to the heater core and connect it at the back of the engine head around the #5 or #6 cylinder. The output would be the return to the pump intake side. I could have the flow direction reversed and I am sure someone will chime in if I do. Does this make sense to you. You can get a standard clear liquid graduated flow meter from a good heating and cooling company that deals with industrial apps.
They will be graduated in gallon per minute and will give you a good idea of our volume that you are pushing.
