Cold start and warm start issue!
Rattle Noise at Idle and Harshness
Injector Pump Leaking
I have an 03 HO with 50K miles. I have noticed two things about my truck over the past 25K miles.
First when it's cold out, below 40 degrees, when you start the truck and take off within a minute or two it shoulds like an old style diesel rattling. Like the pilot injection isn't working. Once over a thousand or so on the tach it sounds like the pilot injection is working again. Is this normal? For sure when warmed up sounds normal.
Secondly I am having an issue starting the truck when warmed up. On cold starts it starts immediately once you wait for the start light to go out. If hot lets say after a 45 minute drive to work and then shut it off. If you start it back up within 10 minutes it will never immediately start. It cranks and cranks then starts. When it does start black smoke comes out of the exhaust. Kinda like it's flooded.
Any thoughts??
Posey-Smoker
Sounds normal, pilot injection only occurs during low rpm ( I can't remember exactly what rpm it shuts down) normal for any cold diesel to rattle - mine will take up to 2-3 miles to quiet down if I don't idle long enough or plug in.
The warm start issue happens to mine too, just occasionally wants to crank for a couple seconds - I think the ecm just wants more revs some times to verify crank sensor signal. Thats my theory anyway-no worries!
There are similar warm start problems with the 2nd generation rams. My 1998. 5 24 valve has a similar problem however, mine will sometimes crank without starting. After 2 or 3 attempts, I will let it crank for 15 or 30 seconds and it will finally start. This prolonged cranking is bound to not be good. What could be the common thread between the 2nd and 3rd gen trucks that would cause the same problem? :confused:
