Little help guys. Last night went to start the truck after sitting for 24 hours in 15 F temps (good cold soak). Had not plugged in the heater, so I cycled the grids twice (waited in between about 5-10 seconds). Turned the key, motor would not catch. Repeated the process again (two cycles with pause), same result. Took 4 tries before she caught, and holy s**t was it rough. Tons of white smoke, took about 5 minutes fort the idle to smooth out. Now before anyone tells me this is normal, my old 92 didn't behave like this, it had to get really cold before I would even get something mildly similar. I have been noticing this to a lesser extent with the onset of colder temps (starting in late october). Some rough idle and white smoke that would last about 2 minutes after startup, beginining with temps about 40F. I have not had the unit back to a dealer since purchase, run standadyne in every tank. All the above symptoms occur without the use of the block heater. Am wondering if I might have a bad injector, seem to recall reading here about injector problems that didn't really surface until cold temps arrived. I have searched the archive, no good hits.
