Fast idle helps
Ron:
Not sure is you have an auto or 5sp, but either way, I find my truck starts much quicker (immediately) when I keep my idle set at or above 850. I do not have to even wait for the heaters at 20 degrees. If starts fine just more white smoke. Heaters just clean up white smoke down to zero but are really needed below zero to aid starting. You might also consider using a winter fuel additive (stanadyne Performance formula, Power Service, or Howes). Many of these have additives that will help (slightly) winter starting as well as keep you from have to use #1 or even blend. If idle is at 800 or more already, something else (fuel shutoff soliniod, no load fuel screw adjustment, timing) could be off alittle delaying the start.
If you have access to straight #2 (big truck stop) instead of winterized, blended or straight #1, I would run it with additive below about 5F. I have had no troubles for 150K miles and 5 winters now down to -30F temps. #2 starts better, better mileage, just need to treat it below 5F. Once running you will not gell, it is only when it has sat in the cold as our trucks have a inline fuel heater. Once running warm fuel is returning to the tank to keep the fuel from cooling off (gelling). It will NOT ungell thick fuel... . that is what the additive is for.
When the engine is really cold, slight foot throttle presure will help as the idle is somewhat lower with a very cold engine. Also, you will have to have very good batteries to cycle the grids more then 2 or 3 times when temps are below -10. They take allot of juiece to run and leave little for the starter. That is why I make sure the idle is set to provide a quick start.
I also use Synthetic oil and because of it (quick oil presure) I do not idle. I start the truck wait for oil presure to stabilize and drive. No matter if it is 20F or -20F. If you have to idle (wife will not ride in a cold truck), carry a stick to jamb in between the seat and the foot throttle to keep your idle at 1200 - 1500. It will warm up quicker and keep things warm if you already have a warm engine.
Bottom line is to drive this like you would a gasser. The coolant runs very cool relative to a gasser but you should get plenty of cab heat. When running around town and never getting to highway speeds don' t expect coolant temps to get to or stay in the Normal range. Not a problem.
jjw
ND
