This morning was the first serious winter we have had in Iowa this year. It was -7 degrees F.
As a test, I had not plugged in the truck, to see how it would do, as it was forecast to get quite cold. It cranked well, but did not want to run. It would try, stumble, trip, fall, and stop when I released the key. I tried cycling the heaters twice before attempts.
After three tries like that, I tried keeping it cranking for about five seconds at a go, and it would keep trying as long as I cranked. I did not crank longer, as starters are not 100% duty cycle devices. I did this five second thing three times, and it was able to continue running on its own when I released the key the third time.
I have clean fuel, and am using anti-gel in proper proportions. Once running, it did just fine, so I do not suspect I had a fuel problem. The steering pump was sure talking about the cold.
My question: Is this typical? I am confident it would not have started had it been 15 below.
Any suggestions? It is plugged in now, but I have concerns about being somewhere... . work, for example, where I can't plug it in, and having it not start.
thanks for your thoughts...
