I know that you are not supposed to let our trucks idle when the temps are cold due to cylinder washing etc. My question is when these 03's go up to high idle is that enough rpm's to let it sit for 5-10 minutes. where I live in New England we are having some of the coldest temperature's than we have had in a long time. Anyhow, I have noticed that in extreme cold it goes to high idle right on startup and not after the two minutes. I have read of others doing this so I am not concerned I just want to know if 1000 rpm's is sufficient enough to let it sit for a few while the thick oil circulates. Also, at work I can not "plug in" and this morning (I worked overnight) at 0' degrees it fired right up with no smoke.
