Cummins Pilot said:For those of you guys that may not know, if you want better heat faster out of your trucks turn on the AC to high and the temp setting to hot. Works great on mine except it won't defrost your windows since it only runs on the vents facing the occupants.
Cummins Pilot said:It hits -50f or worse where I live. Screw the $90 cover. I put two peices of cardboard between the intercooler & radiator. Works great, if I tow I remove one side. Did I mention the cardboard was free.
Cummins Pilot said:I can't imagine it gets cold enough to need a cold front in Louisiana WDixon or do travel to places that get cold?
BigEasy said:Or turn on the defroster, which runs the AC... and defrosts the windows
EricBu12 said:Hi guys,
I'm the one that makes the inserts mentioned above. . I live in the cold weather and you can have these on up to 65 degrees out without heating up. Don't have an ad out right now, just PM me if interrested in a set.
