Cold Weather
Any methods to test pyrometer?
TST PowerMax3....Good or Bad?
Hey all, I am from Colorado. Spend most of my time in the central part of the state as well as some in the southern part. I was down at the southern part for a couple of days and the temps at night hit around 20 below on both nights. I have not added anything to the fuel and only plugged the truck in at night. Start up was fine and it was just a sluggish till it warmed up. I was just wondering if this is enough to do for the truck when it is that cold or if I should take some other steps. Any advice on this would be great.
My advice is to use an anti-gelling additive. I have had my truck stop dead from fuel gelling in +20 degree weather. :mad: I learned the hard way about trusting the fuel dealers to winterize their fuel properly. The additive also helps clean the injectors. :)
Challenger-II is correct.
Also, I plug in anytime it's below 40 degrees. Not necessary at that temp, but it's easier on the engine to start it warmer.
