Column shifter getting stuck.
Htt turbine housing
How much life left on the front band?
Yo Hoot
04 Automatic.
Recently had my trans overhauled by James Transmission Technology here in Midlothian, TX. I have to say James knows his stuff. Trans is tight and shifts perfectly.
I have a feeling this issue has nothing to to with the work done as the first couple of weeks after there was no issue. I think there is something going wrong with the interlock between the brake pedal and the shifter.
It goes right into reverse but many times when I try to shift into drive, it won't go there. When I put it back in park and go directly to drive it most often works but not all the time.
How do I diagnose it?
Not familiar with the brake interlock, but if you wanted to confirm it is not the transmission, you could disconnect the cable at the transmission and operate the transmission manually. Just be sure to set the park brake / block the wheels.
- John
