ob1kobi said:
:-laf
Just trying to see what the purpose was, before this thread goes in the toilet.
Personally I would like to see what people think the pros and cons are for each, I just don't think it will stay civil long enough for it to happen. I am an electronic guy myself but I think all the current big dogs, except for Dennis, are mechanical. Not positive about the sledpullers though.
The big con is the P pump doesn't generate enough injection pressure (using one 'piston' to compress the fuel; I'm pondering a way to use two at once to generate greater pressure). The higher the pressure, the better the fuel atomization will be, and higher injection pressure results in better, more complete, combustion, because more of the fuel is exposed to evaporate and burn.
Unless you want to convert to a Denso pump (that has significantly higher injection pressure), you're better off going to common rail technology and working toward the greatest injection pressures you can achieve (30K-40K PSI comes to mind). Combine such high pressure with a good electronic injection control system (that enables nearly infinitely adjustable injection timing), and you'll have plenty of power. And when you run out of power improvements, you design a custom, high-flow head with solenoid-controlled valves to allow nearly infinitely-adjustable valve timing. CR injection and solenoid-controlled valves will allow operation into much higher RPMs.
When *that* all runs out, you'll likely start mixing 5% racing gas with your #2, because diesel fuel can't burn fast enough to be effective at 8K RPM. Just wait 'til you have a light-weight V8 or TDI running at 10K-12K RPM.
The technology to get high-RPM torque from a CI engine exists or can be made today. It just requires thinking far enough outside 'the box' to figure out what's needed to make it work.
And don't be surprised if you see synthetic #2 (made from natural gas) appear in quantity in a couple years. Biodiesel is good, but it contains too much nitrogen to emit sufficiently low amounts of NOx. But then, who knows; maybe in 20 years geneticists will have designed rapeseed, soy, and other oil plants that will produce low-nitrogen oil.
Oh, the top sled pullers are typically mechanically injected. Today.
N
