common rail ??
Jake exhaust brake cost me a few hp
TSB Issued for 2000 RPM Vibration
i need a brief explaination of a common rail, which i believe my 03 2500 OH has. i understand it to be a fuel delivery system? and why does my son claim that his 93 with a 12 valve ctd is better? says its more "forgiving".
THANKS !!!!
The common rail system is less complex as far as the pump is concerned. The pump simply pressurizes fuel in a "common rail" and the injectors are fired electronically. The previous systems pressurize the fuel as it is needed for each injector fireing event.
I would not call the VE pump on the 93 better but it is diffrent. The new system relies heavily on electronics where his needs none.
-Scott
when it comes to "bombing" , their appears to be an advantage to the common rail system if i have been paying attention. since there is high pressure fuel always available directly at the injector and the injectors are fired electronically, it is only necessary to increase the duration of the electrical signal to increase fueling. that plus changing the timing of the injection event can give substantial increases. this will only help to a given point. beyond that point, higher flow rate injectors are necessary along with turbo and other changes. as far as our fuel pumps go, i am not sure how much high pressure flow beyond factory rates they can handle, but it seems obvious from the claims of the new "boxes" coming out, that it is considerable.
the end result as far as i see right now, is that we will not need to do any pump mods till we get way up in HP/torque. i havent read any threads on pump bombing on gen 3 trucks. is there anything we could even do to them other than raise pressure?
jim
The common rail is quieter, in part because the injection pump doesn't fire the fuel to the cylinders. It just pressurizes it. (Sorry about the spelling)
