Archived Comp Edge install help needed asap.
Archived fuel filter
Archived NV4500 dieing near Ogden, UT
According to the directions #16 - #18. Installing the Boost Elbow. I cannot find the fitting referenced in the intructions. Actully I think I found it but it leads to a vaccum canister of some sort. I think I also read here on the board that if you have an auto transmission that this part of the install couldn't be performed. It only applies to manuels. TIA.
edge comp boost elbow
I just installed the comp box on as well. According to edge, the 2001 dodges with auto transmission have a turbo with a solid wastegate line. you cannot install the boost elbow. refer to the picture in the post above. it's the same pic edge sent to me when i called them up about the same problem your having. Just put a turnbuckle on it. thats what i did, I get about 30 psi max boost.
I don't know if you have an auto or manual, but that is what i was told by edge.
hope this helps
andrew
on a side note, you do not have to have the boost elbow installed for the comp to work, you just wont make that extra 10-15 psi of boost. I drove for a couple weeks until i had time to turnbuckle my turbo to get more boost.
