Ok the comp is installed. I am on the right pump wire I checked it 4 times. It is making a good connection. I have 13 volts inside the cab at the grey wire in the comp harness with the truck running. The comp connector looks to be in good shape and looks to be making a good connection to the comp box. I have tried both grounding to the battery and grounding to the intake.
Having said that the box functions exactly as it would if the pump wire was not hooked up. There is a noticable difference with the box on vs off. However the different levels don't seem to do anything. Every level seems the same. Level 5x5 I can hold wide open from first gear through 6th to 3k and egt will not go over 1050. Boost will hang around 29. Power feels the same as any other level.
So here is my first question. We know the comp box raises the voltage to the injection pump so it kicks out more fuel. Does anyone know what that voltage should be at a given setting? say setting 1 is normal which would be 13. 6 maybe setting 2x2 is 14. 1 and 5x5 is 16. 5. My point is I have a constant 13. 6 at that wire at all times. Does this mean the comp is bad? I asked the guy I spoke with at comp that question he didn't know what the voltage should be. He seemed to think my injection pump was bad. There has to be a way for me to check this thing with out having to send it back to Utah.
Is there something I'm missing here? All connection have been checked a few times over. I do not have a fuel pressure gauge but my lift pump was bad and I just replaced it 4 days ago. So I'm guessing pressure should be good. A friend of mine has a test gauge I am going to hook up later tonight and see what it's at.
Any help would be appreciated.
Thanks Rob
Thanks Rob
