Engine/Transmission (1998.5 - 2002) comp question...
Engine/Transmission (1998.5 - 2002) Edge EZ and boost
If i remove my comp will the truck still run ok with the 275's? i heard somewhere that its a must to have some kinda fueling box if youve installed different injectors am i right? reason i ask is i may be trading my truck in for a 3rd gen and i would like to keep the comp to sell rather than leave it in the truck.
-Jon
It will run just fine.
Its not the fueling part of the comp that makes injectors really shine, its the timing.
Those injectors aren't really big enough to NEED much advanced timing, so I'd say you're safe.
-R. J.
I think the issue is setting an over-boost code. That's likely to happen if you leave the Edge boost elbow in place. Just replace the Edge elbow with the stock elbow and boost should stay down in the normal range.
