Compatible Parts from Salvage 2000
Fuel tank vacuum
Replacing front ball joints
Related interior trim panels will be different, floor shifter bezel, steering column trim, od button, odometer. PCM different, under hood accelerator hardware different. Possibly a few other odds and ends.
Body parts will interchange. Front bumper brackets will work, but you’ll need to re-drill one hole. I can’t remember, but the grille may not fit your hood without drilling some holes. Lights will interchange. transmission and pedals will interchange. Pretty much anything engine related will not interchange. Wiring and connectors will also be different. As mentioned, the interior will be different, too. Wheels and tires will work. The front axle and brakes MAY be a bit different, I can’t remember.
