Complete 03 HD Ram GVWR/tire chart
Exhaust brake a factory option?
Lhaf
Models and GVWRs
2500 2WD and 4WD
- Reg Cab Hemi - 8650
- Reg Cab diesel/V10- 9000
- Quad SB Hemi - 8800
- Quad SB diesel/V10- 9000
- Quad LB Hemi - 8800
- Quad LB diesel/V10- 9000
3500-SRW 2WD and 4WD
- Quad SB diesel - 9900
- Quad LB diesel - 9900
No regular cab 3500 SRW, and no gasoline engines.
3500-DRW 2WD
- Reg Cab Hemi - 11000
- Reg Cab diesel/V10- 11500
- Quad LB Hemi - 11000
- Quad LB diesel/V10- 11500
3500-DRW 4WD
- Reg Cab Hemi/V10 - 11500
- Reg Cab diesel - 12000
- Quad LB Hemi/V10 - 11500
- Quad LB diesel - 12000
Tires
All season tires:
2500
- LT245/70R17E Michelin LTX A/S, 3000 pounds @ 80 psi
- LT265/70R17E Michelin LTX A/S or Goodyear Wrangler SR/A,
3195 pounds @ 80 psi
3500 SRW
3500 DRW
- LT235/80R17E unspecified Goodyear, 3085 pounds @ 80 psi
Off Road tires:
2500
- LT245/70R17E BFGoodrich Rugged Trail T/A, 3000 pounds @ 80 psi
- LT265/70R17E BFGoodrich Rugged Trail T/A, 3195 pounds @ 80 psi
3500 SRW
3500 DRW
- LT235/80R17E Goodyear Wrangler GS/A, 3085 pounds @ 80 psi
2500/3500-SRW wheels 17x8 steel or aluminum
3500-DRW wheels 17x6 steel
Hrm, that throws a wrench into things. I didn't order the offroad tires on my 2003 because on my 2001 I only got michelin MTX's as the offroad option. . But since my truck's on restriction, I could probably upgrade to the BFG's still.
Decisions, decisions. . Thanks for the info, KC. :D
2500 wheel size
I saw two 2500's with minimal options in Winchester KY and the standard steel wheels were listed as 17x7. 5 and had the 245/70 BF Goodrich tires.
Ironically, BFGoodrich tires are made by Michelin, and the on/off-road tires are listed as "Michelins", while every one I've seen is the BFG Rugged Trail T/A. To the letter of the law, Michelin is technically supplying both Mich and BFG tires.
As far as that 17x7. 5 wheel - that is likely correct. There are some discrepancies in the spec sheet, and this is one of them - besides 17x8, there is also a typo that says "17x7. 7", which is likely the 7. 5.
Where the typos appeared in the specs, I erred on the side of the obvious :)
3500 DRW All Season Tires
In Mt. Sterling, KY I saw 3 3500 DRW's and they all were shod with Goodyear Wrangler SR-A's, both for 4x4 and 4x2.
