Matt400 said:Well the first thing that comes to mind is the astronauts of Apollo 1 who died from an electrical short which ignited a oxygen- rich environment that then fed on other combustible materials in the spacecraft.
Oxygen related fires can feed on just about anything so things you think wouldn’t normally burn do with pure oxygen. Its why safety standards say not to smoke around the stuff. A known danger is opening the cylinder valve too fast which can cause temperatures to rise high enough that the heat alone will become the ignition source. I would think a fast release of pure oxygen onto the turbo impeller could provide the same result and once the fire starts there is no shutting it down as it burns its way back to the source – a 2200 psi tank.
1. Apollo 1 was basically a pure oxygen environment. Once the oxygen leaves the nozzles at the compressor housing, it's diluted with air, so we're only talking about increasing the oxygen content of the air by percentage points - as I said, maybe from 23% to 30%, and the percentage increase will drop as turbo airflow increases.
2. As we drop the pressure of a gas, its temperature drops. To prove this to yourself, go out to your truck and depress the Schrader valve on one of the tires that's at ambient temperature. Does the escaping air feel cooler than ambient temperature?
Our company builds industrial compressors that handle oxygen, hydrogen, hydrocarbon gases, etc. , so I'm familiar with (and cited) the warnings about maintaining the oxygen system up to the nozzles as a pure oxygen system in an earlier post.
Again, oxygen isn't a fuel, it's an oxidizer, so oxygen can't "explode" in the absence of a material that it can rapidly oxidize - there has to be a fuel source present, although that can be the oil off your hands, iron or steel shavings, etc.
Rusty
