since rain stopped here in cali im getting serious condensation on windsheild, carpet is bone dry and checked clearence lights everything looks a ok, does anyone have an answer for this problem.
jake
jake
Kirwin said:Another common cause of condensation right after start up is caused by shutting off the truck with the heater control in the defrost mode. In either of the two defrost positions, the A/C compressor runs to dehumidify the air depending on the temperature of the evaporator coil. When the truck is subsequently restarted the water in the A/C drain pan is still present and the first puff of air that comes out is saturated with moisture. When this air hits the cold windshield instant fog/frost depending on outside temperature. it is hard for the defroster to remove as there is no heat to evaporate the moisture that has condensed on the inside of the windshield. My dealer sugests to put the heater in any position other than defrost or recirc, turn off the A/C and run the fan on high for a minute or two prior to shutdown to prevent or at least minimize the effect. My experience with coolant leaks is that they cause extreme fogging as there is a constant supply of hot water to produce saturated air. Additionally there is the very distinct smell of antifreeze. Hope this helps. Ken Irwin
