I'm planning on just tiring into the vent line and I have a Holley pump that I'm going to use to do the transferring. after reading through this, I will be putting a 5 psi check valve in to prevent siphoning. but now I'm concerned with another thing, I have a 2014 and I have bought the Geno's filler plug which is solid rubber, no venting, if I pump a high volume of fuel in, where is the air going to escape?? Am I going to inflate the stock tank? I had read somewhere in the past that the filler neck on these new trucks have a overfill drain that dumps the fuel out inside the fender if you top up the tank while filling it normally at the pump, which I would think would allow air to escape as well in the transfer process. has anyone done a rule transfer system with a pump and Geno's plug in the filler neck?
I definitely need the filler neck plug. I just picked up the new truck on Monday and when i got it home, there was already a little snow in the filler spout!!!!! that was after only 20 km's of driving in the snow. so much for the sealed filler door!
