Greetings,
Well I am trying to do things right with this truck but I am getting my #$% handed to me every time I turn around. I have picked up a constant miss through all rpms. I just had the injector pump set by a professional shop. The timing was at about . 5mm and they moved it to about 1. 5mm I think. The diesel noise was noticably louder. The max mph in each gear went up about 2 mph. It seems to have slightly more power although it still won't hold 5th towing. The mileage has dropped from about 10 towing to about 8 mpg. The fuel smell is much stronger - bad at idle. Now it has a miss after about 500 miles. I have run Stanodyne fuel treatment for the last 6000 miles. It sounds like a gasser with a fading plug or wire. Any ideas??
Thanks in advance
Also - any reputable shops in the Black Hills of SD or near Denver? I don't mind paying for expertise if they get it right the first time.
Thanks in advance
