I am cutting this out of the topic New high idle controller hopeing to get more response to something I feel would be an excellent mod to our trucks,so it may seem a bit out of context.
jponder,I like your idea for the constant throttle cruise. I even have an extra $99 magnetic sensor CC without a home. Was your idea to use the $99 CC's vacuum servo(does the 24v use one of these,I have a 12er) or just tie into the existing factory servo if it's compatible with the $99 CC's electronics?
It seems like a rheostat supplying voltage to the control pin on the servo would also work,but it would take some wiring and a relay to include the brake safety feature. Would also need a diode to isolate the pcm from this voltage. You would then have a dial in steady rpm and a resume button. You could use this for warm up rpm and for driving. Could also use the factory CC if you wanted. Would be safer than a tractor type throttle,especally with a auto where you can't disengage by pushing in the clutch. Seems pretty cool to me.
I have found I get better mileage using my foot rather than the CC. I was driving into a strong,gusty headwind a couple of days ago. With my foot on the throttle pedal and the CC engaged I could feel the throttle moving with the gusts,not good for fuel economy. Started using just the pedal and my speed remained pretty constant without all the varying the CC causes. Even noticed with using my foot that when strong wind gust came that the boost climbed with it.
I think that if we put our heads together we can come up with a very useful add on. My wiring diagrams leave much to be desired in this area,would like to see what the voltages to the servo run.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(work truck)
95 3500,5 speed 3:54,BD E-brake,Driftwood,Banks&Psycotty,34,000 GCVW apple and tractor hauler(works harder truck)
