Engine/Transmission (1998.5 - 2002) Continuous Duty Alternators
Engine/Transmission (1998.5 - 2002) HELP! with Turbo Install
Engine/Transmission (1998.5 - 2002) Block on ebay
Hi All, this is a clip from a place that has alternators, anyone had any experience with either the alternator or the internet retailer? Don't want to buy a pig in a poke, or from the piggy either.
They are designed to be used in vehicles that are "Daily Drivers". They come with a 1yr. warranty against parts and labor (no mileage, months, or hours, strictly 1 yr. period). Hope this helps! I am heading out for the night, but I will be back in on Monday morning bright and early, if you want to order this bad boy. Have a great weekend!!
Best Regards,
Josh Reed
----- Original Message -----
To: -- email address removed --
Sent: Friday, February 25, 2005 4:36 PM
Subject: Re: Form Results from HO Website
In a message dated 2/25/2005 5:14:47 PM US Eastern Standard Time, -- email address removed -- writes:
I have a 200 amp direct bolt-on replacement for your application. This unit is a Denso, part # 67054, and is priced at $649.
_________________________________
Hi Josh, is this alt rated for continuous service? What's the warranty on the alternator? Mileage? Months? or Hours?
Cheers,
Steve J
pa performance
there a guy in PA that does customer alternators for the 5. 0. .
He can build you anything you what at any rpm range and output.
Ask for Rick at www.paperformance.com He's the man and will treat you right. And he gives a life time warranty
master, had my rear end worked on around a month ago. Admittedly, my posterior is in need of service call.
Cheers,
Steve J
Yooper, I heard from Rick today, no go. . .
Unfortunately the alternators used by Dodge in the truck line are all Nippondenso and Bosch made and there are really no known reliable upgrades for them. If you had a Ford or GM we may have some options, but in this case we are not going to be able to help. Thanks for your inquiry.
Rick
Guess I'll see what O'reilly has to say.
Steve J
I have 220 amp
hey OTRPU,
I have an Ohio generator alt that is rated at 220 amps peak with a one year warrenty. The nice thing is that I ordered it with a smaller pulley on it so I get more amp output at lower rpm, seeing how our trucks are running the same alt as the gassers. I run a full audio system and a plow and it works like a champ. I can check the price but I remember it being around $500.
