rbattelle
Just thought I would let those with the Painless Wiring auxillary fuseblock know about a convenient mounting location I found.
On both ends of the dash there is a plastic panel that clips into place (I have heard that 2nd gen trucks have their fusebox behind the drivers side panel). Anyway, there's enough room on the passenger side to get the entire fuseblock in there, but not enough room to screw it in place... you have to just sort of let it sit in the bottom of the compartment. So I soldered a short piece of 12 GA wire onto the Painless ground terminal, then drilled a 1/4 inch hole in the metal dash support on the truck and secured the ground wire with a ring terminal and 1/4-20 bolt and locknut.
There is an ultra-convenient path just under the glove compartment where all the wiring can be tucked up out of sight and routed to the drivers side and whatever gauges/accessories you have. The auxillary block remains hidden behind the factory plastic panel, but is simple to access.
If there's enough demand and interest I'll take a few pictures and post them... enjoy.
