2nd Gen Non-Engine/Transmission Converting a 2001, 2500 to a full non-duel Dana 80?
2nd Gen Non-Engine/Transmission dirty axle tube questions???
Engine/Transmission (1998.5 - 2002) Transmission Fluid Change
Hello to all and a big thanks in advance. I have a 2001, 2500 with a 3:55 ratio and would like to go to 3500 springs and a full Dana 80 axel assembly without duels. Can I just change the studs on a 3500 axel and bolt it in? Are the U-joints the same between the 2500’s and the 3500’s? Are the wheel cylinders for the brakes bigger on a 3500 axel than the 2500 (drum brakes)? Also does anyone make a set of overload air bags that mount inside of the frame rails for this truck? All I have found are outside and there is not much room for tire chains. Thanks again for the help…………Charlie
Do a search on rear end swap. Numerous threads on this. What I remember is:
Wheel cylinders are different
Spring Perches are different
U bolts are different
Drive shaft will have to be shortened
I was wanting rear disks and contemplating the Dana 80 swap. I found a Dana 70 for a 2500, so I ended going that route
Good Luck
Joey
