I would like to get a idea of a (proper) way on changing out the coolant. I for one will not have to be doing it anytime soon on the 03 CTD (I hope). But do you think that, they use distilled or demineralized water at the factory when coolant is added (according to the way the manual, says to use when changing out the coolant). Cars, and trucks I had before , when it comes time to change, I just drained the coolant from the radiator in a bucket, and add water from the garden hose to the radiator, then run the vehicle with heater on up to temperature to flush the system (maybe a couple of times). Then drain the water (after vehicle cools) out and perceed with using or (guesstimating) a 50/50 mixture to refill (with in mind there's still water holding in the engine block itself). A mechanic friend of mine, said he never use's the radiator flush you can buy, that he had problems before on different occasions where the heater core started leaking soon after wards. I believe the manual says 7 gallons for the 03. If you use a premixed coolant is'nt there still water trapped in the engine block, and you would not have the right coolant to water ratio. Also view points on the distilled or demineralized water thing.
Is that really necessary!
